90k Maintenance?
Old Mar 21, 2008 | 06:49 PM
myxyzxo's Avatar
SoCal Crew Member
Default 90k Maintenance?
Ok so my 225Q has hit 91k and the service light came on. What maintenance should I be doing at this point? Pls respond.
Old Mar 21, 2008 | 08:00 PM
themysteryman83's Avatar
Default RE: 90k Maintenance?
Hard to say... we would have to know previous service history and intervals...
Old Mar 21, 2008 | 08:46 PM
myxyzxo's Avatar
SoCal Crew Member
damn. i just recently purchased the car in Nov. When I got it, it had 80k.
Old Mar 21, 2008 | 09:01 PM
eliTTe's Avatar
if you got it at 80k it probably didn't have the haldex fluid changed, you need to do that ASAP!(quattro only) and 90k is just a oil change and visual inspection etc, also you should probably change the spark plugs if you haven't done so yet.
Old Mar 21, 2008 | 09:07 PM
myxyzxo's Avatar
SoCal Crew Member
ORIGINAL: eliTTe
tyvm.. but what is a haldex fluid? Can I pick it up at a local auto zone? Also, what type or oil should I use? I hear an annoying ticking sound.
Old Mar 22, 2008 | 12:09 AM
eliTTe's Avatar
haldex stuff is a dealer only item to buy locally, or you can order it off ECStuning.com and requires a special wrench for the filter. use castrol 5w-40 or mobil 0w-40 for the engine oil.(there both vw-502 approved)
Old Mar 22, 2008 | 02:00 AM
jakej's Avatar
tb needs to be changed. Big $$$
Old Mar 22, 2008 | 11:00 PM
myxyzxo's Avatar
SoCal Crew Member
TYVM for the help. Really appreciate it.
ecjr173
Nov 19, 2007 10:42 PM
Wintermute
Aug 28, 2007 10:02 AM
coma
Oct 8, 2006 07:22 PM
Audinam
Apr 17, 2006 06:55 PM
