Acceleration weakens!
Old Dec 3, 2009 | 02:57 PM
kennyk's Avatar
Default Acceleration weakens!
Hello,
I have finally drove around in nurburgring this Tuesday! Then I noticed that my TT (1.8T yr2000) was going fast with good acceleration at first. As I drove on for 6 minutes or so with excessive braking and constant full throttle acceleration, I noticed acceleration was getting weaker. I am wondering if it's the turbo that just can't provide more punch simply because it's old? or could there be some other possible causes? The mileage is about 10,000 Km. The temperature seemed fine on the Temp gauge. Enough engine oil. The timing belt have been replaced already a year ago. Mods I have done which could have any relations include : chip, Remus exhaust, downpipe, Forge splitter (Full-recirculation set up). Any advice (including wild guess) would be appreciated.
Regards,
Ken
Old Dec 3, 2009 | 06:44 PM
jakej's Avatar
I would guess you have a boost leak.
Old Dec 3, 2009 | 11:38 PM
mandito1980's Avatar
does you RPM's go up and you get no acceleration?
If it is I just had a similar problem my car was too slow on take off and whenever i wanted acceleration i got very little, with the rpms going going up...
turned out to be my clutch i replaced it and now it runs like a champ
i have a 2000 1.8 as well.
good luck
Old Dec 3, 2009 | 11:39 PM
you do want to check for the small things first like vac leak. bad MAF
is your check engine light on?
Old Dec 4, 2009 | 08:31 AM
kennyk's Avatar
Hey guys, thank you all for the tips. I have just made an appointment with the people who chipped my car and they gonna check if anything is wrong with my car on next wednesday. I briefly explained the sympton over the phone and the guy think it's likely the intercooler getting too hot. I will keep you guys updated after the thorough check up.
Old Dec 10, 2009 | 05:57 AM
kennyk's Avatar
Hi, I have gone to the garage. They checked through ECU setting and other stuff by connecting laptop to my TT. They found my LAMBDA sensor (the 1st one) is faulty. So that needs to be changed. The guy also suggested I change Intercooler if I get a chance. The air temp goes up to around 60 C degrees, while it should stay around 20 to 30 C degrees. He also suggested to change FPR (Fuel Pressure Regulator) from 3bar to 4bar. So I have it ordered on http://www.worldcarparts.co.uk/CarPa...8/Default.aspx
According to them, there really isn't any serious problem with my car. Checked around hoses for leak in engine bay, but nothing weird was found.
Now I have to look for how to replace FPR and look for good deal on a LAMBDA sensor.
I will change the intercooler, but not high priority for now. Maybe in the future when I also want to change the turbo.. some day.
noir
Jul 29, 2013 11:51 PM
ninetythree90S
Mar 27, 2008 06:17 PM
alias747
Dec 9, 2006 02:11 PM
XansMom521
Feb 27, 2006 12:52 AM
Dudek12
Feb 13, 2005 09:33 PM
