Aftermarket Headunit
Old Apr 14, 2008 | 03:48 PM
keefboz's Avatar
Default Aftermarket Headunit
Has anyone changed out the head unit on their TT? If so, how hard is it and how long did it take? I have the installation kit, just wondered if I should even attempt it by myself.
Old Apr 17, 2008 | 07:11 PM
keefboz's Avatar
Default RE: Aftermarket Headunit
ok,if anyone has installed an aftermarket unit please help me out!
i installed the unit,but the only way it will work is by connecting it to the 12 volts constant with the memory, which means it doesnt turn off when the car is turned off! the acc lead didnt do nothing and the dimmer did nothing when it was connected. the harness i bought, which was from metra and cost 30 frikkin dollars was basically wired wrong. i know this because i was following the diagram on the stock unit!!!!
what do you guys think i can do to get this wired correctly, i have already spent so much money on the harness and crap i dont want to pay to get it installed properly!
Old Apr 17, 2008 | 10:55 PM
themysteryman83's Avatar
You need a metra 1787 harness to connect to the bose concert stock system. You will also need a ground loop isolator for the rca'sif you're using the stock amp. Wiring is super easy and is nothing like you described. Sounds like you got the wiring all wrong or got the wrong harness.
Old Apr 18, 2008 | 03:54 PM
keefboz's Avatar
i dont have the bose system! and the harness says it is for my vehicle!
thanks for the help though i appreciate your time bro
Old Apr 18, 2008 | 05:57 PM
jakej's Avatar
woo. Just wondering what kind of stereo does it have then? I haven't seen a non bose. Not saying your's isn't, I'm just wondering. I have the window sticker and it's a $2k option... what a joke.
Old Apr 18, 2008 | 06:22 PM
Blue01TT's Avatar
okay sorry to thread jack but i went to install my headunit today and couldn't the key on the left side of the stock head unit to grab. I tried wiggling it turning it upside down backwards and every other way i could turn it. Is there any other way to get the stock bose headunit out with out having to drop the whole lower dash?
Old Apr 18, 2008 | 07:06 PM
achTTung's Avatar
Nope, that that I know of. I know I did have trouble with mine the first time I tried to remove it, same problem. Eventually felt it out and got the removal tool to catch.
Old Apr 19, 2008 | 02:53 AM
ORIGINAL: keefboz
Hmm, in that case the stock nonbose unit uses hot outputs instead of the preamps like the bose does. I believe that in order for you to use them you need the correct harness. I don't know which one it isthough with the non-bose system. I think the harness is the same but the wiring is slightly different...
Old Apr 19, 2008 | 09:13 AM
keefboz's Avatar
i think your right, i am going to head back to the audio place today and see if it can get sorted, again I appreciate the help all!
ajohnson187
Jul 9, 2012 05:34 PM
Skiredhot10
Feb 18, 2009 11:03 AM
MK1audiTT
Aug 26, 2008 06:19 PM
caledonia112
Apr 8, 2007 07:39 PM
Glasgowbhoy
Aug 4, 2006 03:03 PM
