Air conditioner
Old Jul 9, 2007 | 11:58 AM
moeron7's Avatar
Default Air conditioner
Is there a way to make my AC colder by adding freon or something? I swear it used to be a lot more colder. Also my car shakes pretty bad when I turn it on, could it be loose somewhere?
Old Jul 9, 2007 | 02:54 PM
moeron7's Avatar
Default RE: Air conditioner
Anyone? Its freakin hot here!
Old Jul 9, 2007 | 02:59 PM
cincyTT's Avatar
I'm make believe
if your a/c is not cold you either have/are:
low on freon
a/c compressor going bad
hole/leak in the a/c lines/condensor.
You probably should get it tested, should cost to much if anything.
Old Jul 9, 2007 | 03:08 PM
theTTkid's Avatar
my car shakes when i turn the ac on too... its normal
Old Jul 9, 2007 | 03:24 PM
moeron7's Avatar
ORIGINAL: cincyTT
low on freon
Thanks, know of any DIY links for adding freon?
Old Jul 9, 2007 | 03:28 PM
cincyTT's Avatar
I'm make believe
its not recommended because you cant remove the air from the system with the diy kits. so it wont be nearly as cold. Just get a recharge the correct way and if there is something else wrong, the a/c people will know and find it.
Old Jul 9, 2007 | 07:09 PM
shkenned's Avatar
I thought mine was on the fritz, then i realized i had at some point hit the "Econ" button......yea, i felt stupid....
Old Jul 9, 2007 | 11:14 PM
nugger's Avatar
Mine is exactly the same, tried the recharge still same, put the ac on with the fan going full & the engine revs up & down, weird
Old Jul 9, 2007 | 11:32 PM
rayveedub's Avatar
go to a shop, dont try to charge yourself with those part store kits they contain dye's and leak fillers. also you dont use freon, its r134a.
unicorn58
Jul 25, 2024 03:38 AM
dogchainx
Aug 4, 2010 02:54 PM
bauer1185
Jun 15, 2008 02:10 PM
mnflake19
Jul 23, 2007 02:57 PM
ueberbill
Oct 24, 2005 04:50 PM
