Alarm brands
Old Feb 27, 2008 | 12:38 PM
  #21
GreekTT's Avatar
Default RE: Alarm brands
grrrr.... so what happens now??? how do i make the alarm set off without the panic button??? maybe i should try what you recommended cincyTT
Old Feb 27, 2008 | 12:40 PM
  #22
cincyTT's Avatar
I'm make believe
That would be the easiest. If it doesnt go off, the sensor could be off so press that button
Old Feb 27, 2008 | 12:42 PM
  #23
doadea's Avatar
ORIGINAL: cincyTT
What button is this that you speak of? If you are talking about the series of three buttons near ash tray, one being the gas tank, one being the trunk, and in my case, the third is a blank..I know this from whenI removed it to install my basslink controller.
Old Feb 27, 2008 | 12:44 PM
  #24
cincyTT's Avatar
I'm make believe
Maybe they deleted it by 04. We early models all have them
Old Feb 27, 2008 | 12:47 PM
  #25
doadea's Avatar
ORIGINAL: cincyTT
Hmmm...I am going to have to check my bentley when I get home.
Old Feb 27, 2008 | 12:49 PM
  #26
GreekTT's Avatar
well my model is 2002 so it should have it.... still it doesnt.... i ll check what the middle button does also!!!
Old Feb 27, 2008 | 10:01 PM
  #27
vegastt's Avatar
I would try something simple... close your doors, push the lock button then try opening the door.
I've forgot tounlock my door plenty of times and each time the alarm goes off.
Old Feb 27, 2008 | 10:15 PM
  #28
XCLR8TT's Avatar
The sensor itself is located in the little grill above the rear view mirror.The button by the ashtray disarms the motion sensor. The easiest way to test it out is to roll the window down. Lock the car with the with lock button on the key remote. Check to see if the lights are flashing. Reach your hand in the window and move it around.
Old Feb 28, 2008 | 04:28 AM
  #29
GreekTT's Avatar
guys i have done all that and it didn't work... maybe the sensor needs tuning or something.
the only thing that worked was the following. I rolled the window down and I locked the car remotely from my key. Then I unlocked the door with my key and when I sat on the seat it went off!!! I tried moving my hand in the window space but the sensor din't pick up anything!!!
Anyways... when the thief is seating and about to roll.... I will probably notice it... hehehe
Old Feb 28, 2008 | 09:42 AM
  #30
doadea's Avatar
Well, last night I played with my alarm a bit in response to this thread. I rolled windows down and locked doors via remote. Red light was blinking. I reached in and waved my arms all around and nothing. I reached in and opened the door from the inside and my alarm went off. I have no button as far asI can tell to turn the motion detector on or off, butI take it mine is off somehow. Any suggestions?
Danny510
Jan 20, 2010 12:49 AM
a2thy
Feb 19, 2009 12:29 AM
kolan67
Oct 4, 2007 07:35 PM
beefski
Feb 2, 2006 07:35 PM
droo587
May 20, 2004 05:50 AM
