Anyone install Dynamat or other?
Old Aug 28, 2008 | 05:11 PM
bvgoosedd's Avatar
http://colomar.com/Shavano/dvc_spkr_wiring.html
check it out you can wire dual 2 ohm voice coil subs with a 4 ohm load or a 1 ohm load. ur amp is 2 ohm capable. meaning you'd have to run your sub using 4 ohm load if you wire the sub on 1 ohm you'll fry your amp. now do you have two subs???? then your golden too. but only if you amp can handle both those subs. and also rms is the watts you sould be matching. not peak. just to give you a heads up. and keep in mind i'm just trying to help not make anyone think they are wrong or anythin like that.
chowmouse
Jun 25, 2011 11:22 PM
andrewj654321
Aug 18, 2008 10:22 PM
AudiBlack87
Mar 4, 2008 01:49 PM
timbo108
Feb 28, 2007 07:11 PM
