Is the APR R1 supposed to honk?
Old Oct 5, 2007 | 07:21 PM
JettaRedII's Avatar
Default Is the APR R1 supposed to honk?
I opened up my airbox by essentially cutting out the end away from the engine. Now it gets unrestricted airflow to the stock filter. However, you can hear everything on the intake more clearly. Not as bad as a cone filter, but close.
The problem is now at part throttle, I hear a hum or honk that sounds like diaphram vibration. I swapped in my Forge 007P and the noise goes away.
I really liked the R1, but don't like the noise. I opened it up and the diaphram looks intact (the thing is brand new), so is this just the characteristic of a diaphram type DV?
Old Oct 5, 2007 | 07:34 PM
cincyTT's Avatar
I'm make believe
Default RE: Is the APR R1 supposed to honk?
there shouldnt be any vibration. Reinstall it and give it a day of to to adjust and see if it goes away.
Old Oct 5, 2007 | 09:11 PM
JettaRedII's Avatar
Well, I replaced the spring with the green spring out of my Forge kit. The green is the weakest Forge spring, but it is still stiffer than the spring that comes with the R1. No more honking and back to smoothness!
Old Oct 15, 2007 | 11:25 AM
patty AT forge's Avatar
ORIGINAL: JettaRedII
Hmmm.
Old Oct 15, 2007 | 05:17 PM
AudiOso's Avatar
Funny... mine doesn't make any noise and works just fine as it came from APR.
Old Oct 15, 2007 | 07:33 PM
cmh's Avatar
cmh
Mine works awesome too-
Old Oct 16, 2007 | 09:05 PM
quattro411's Avatar
you might have gotten one out of the bad batch, there is a lifetime guarantee so I would just send it back to be fixed or get a new one
Old Oct 16, 2007 | 09:45 PM
MeanAudiA6's Avatar
i just ordered one so we will see.
bemor187
Feb 9, 2009 02:41 PM
02A4Turbo
Aug 24, 2008 08:38 PM
born to run
Jun 30, 2007 01:41 PM
megawatt_inferno
Oct 29, 2006 09:04 AM
