Audi TT mods?
Old Oct 13, 2008 | 07:02 PM
theTTkid's Avatar
turboxs... seriously. its sooo easy to use and the **** isnt worth the money
Old Oct 13, 2008 | 07:31 PM
jojoenglish85's Avatar
Ya I also am using the TurboXS, its so much easier and worth the money, plus it looks alot more attractive under the hood Besides your Aftermarket DV and TurboXS Under your hood will retain more of a stock looking presence. Unless you have overhauled all of your Turbo Hoses then it looks modded but even then it still looks stock.
Old Oct 13, 2008 | 07:45 PM
drsmith's Avatar
heres a question i'd like to throw out there.... when having a remap via ARP, Revo etc... i am presuming they alter the timing, fueling as well as up the boost.... does this not confuse the ecu when running a turbo xs as i am presuming it will be upping the boost higher than what the map suggests?....
just something i was thinking about this afternoon... i want to run the turobxs and simply leave the n75 oojit in the loop so as to not confuse things..... anychance of making things unreliable? whats safe boost on a standard engine, intake, dp etc...?
Old Oct 13, 2008 | 07:49 PM
Wintermute's Avatar
Best dv evar.
Eurojet.
Old Oct 13, 2008 | 08:03 PM
As far as the tune goes, i think its meant to self adjust depending on where you put your boost. Its techicaly the same if you don't have a tune and you change the n75 for the new MBC your cpu adjust, and sometimes it goes into limp mode. easiest way i have had so far, is to just remove the n75.
Old Oct 13, 2008 | 08:09 PM
drsmith's Avatar
how difficult is it to remove the n75? i seem to recall people having issues after removing it and being advised to keep it in the loop but have it over ridden by the MBC?...
while im on topic, im buying a boost gauge and would like to know whats the best option considering price, quality and accuracy
Old Oct 13, 2008 | 08:13 PM
keefboz's Avatar
I got a stewart warner guage and installed it myself, works fine and matches the interior lighting really nicely.
Old Oct 13, 2008 | 09:48 PM
  #18
theTTkid's Avatar
drsmith, you want to do what i did... you can leave the n75 in no problem with the turboxs, boost gauges is personal preference...
my O.CT program wasnt enough, it only put me to about 15 psi, haha.. lame, so im up to 22.6psi according to my liquidtt handy dandy toy and i have no trouble with the car
Old Oct 13, 2008 | 11:28 PM
  #19
drsmith's Avatar
ahh ok sounds good to me!...
thanks for all the info, hopefully my new MAF should be here tomorrow and i'll order my new hazard switch relay from the dealer too, that should be the car running sweet... then its boost gauge, turbo xs and dp! woohooo
Old Oct 14, 2008 | 05:20 PM
  #20
Wintermute's Avatar
Here is stage 2 revo infomation: http://www.revotechnik.com/products/revoStage2.aspx
ImTheDevil
Sep 21, 2014 10:07 AM
vanilluh
Aug 17, 2011 10:20 AM
duud40
May 12, 2007 07:34 PM
bmwtoaudi
Oct 26, 2006 04:43 PM
