Bad Noise up front
Old Nov 17, 2007 | 08:44 PM
TracAction's Avatar
Default Bad Noise up front
Ughh I had to get towed home 60 miles thank god for AAA Plus!
so my problem is I was cruising down the road when i noticed a slight "burbble" comming from the engine bay But only when I was light throttle basically maintaing speed. the noise stopped ifI accelerated or decelerated. After about 3 miles Burbble is now more like a grinding curchunk sound and started to get a slight vibration. So I stopped checked it out didn't see anything obvious from the side of the road. I tried going again but slower and it was Much worse NOW so as I was stopping again only went like 20 yardsI noticed ifI tap the brakes or accelerate is stopped making the Horrid sound. other than that the car ran fine accelerates good holding boost nothing else odd just was getting bad sounding quick
Any Ideas where to start?
and yes my Vag-com came fedx on friday (just gotta figure it out now)
Old Nov 19, 2007 | 12:09 AM
TracAction's Avatar
Default RE: Bad Noise up front
wow no one had any opinions?
I am going to start by checking out the drive lineI guess, as it was only doing it at partial load. Accelerating and decelerating nothing unusual heard?
Old Nov 19, 2007 | 01:01 AM
Murderface's Avatar
It could be anything dude...
Personally, sounds like part of your clutch assembly, that's usually what makes for nasty grinding/clunking noises.
Old Nov 19, 2007 | 01:38 AM
rayveedub's Avatar
ummm burble isnt helping to diagnose. more info would be helpful, any vibration? does it get worst and any rpm? cel?
Old Nov 19, 2007 | 01:46 AM
TracAction's Avatar
Nope no vibration .....no Cel....I was at an autocross event that day and it happened on my way home came on real sudden one min fine then over like 2 miles it was BAD
Ok it sounds like (don't ask howI know this) if you forgot to tighten the lug nuts on a wheel ..... starts out soft then get much louder and has a rotaional noise ... i know hard to describe. but there was no vibration and yes all the wheel studs were on tight.
Old Nov 19, 2007 | 01:56 AM
rayveedub's Avatar
did you do a wheel bearing test? i doubt its that though. does it sound like something grinding or metal grinding. what about going around turns, any better or worst?
Old Nov 19, 2007 | 02:03 AM
TracAction's Avatar
No didn't noicte a change when turning but i was on a strait section of road.
I have to jack it up and see if there is play for a wheel bearing check right?
Old Mar 14, 2008 | 05:57 PM
Hitchr10's Avatar
Did this ever get resolved? What was it?
Hitchr10
Mar 14, 2008 05:59 PM
hoovis
Aug 24, 2006 01:42 PM
Chad021179
Feb 7, 2005 09:13 PM
NJ01A4
Jul 20, 2004 04:09 AM
