Been to the site, but Cant figure out ...how much the mod shack intake is!?
Old Jan 9, 2007 | 02:20 PM
bmwtoaudi's Avatar
Default Been to the site, but Cant figure out ...how much the mod shack intake is!?
Hey guys,
I'm looking at upgrading a couple things.
My intake, Its killing my turbo!
I have a chip and exhaust...time for the intake, im considering the modshack intake as most suggest it.
How much is it?! I cant find the price anywhere.
Also My clutch is slipping and im replacing it...found a few good ones, found a stage 1 for $350 and a Stage 2 for $450..... should I just go with the stage 2? Will it hold up better?
Only mods im going to do:
Intake
Exhuast
Chip
Considering changing from the k03 turbo to the K04
Will the stage 2 be of any benifit? or will the stage one be fine?
Old Jan 9, 2007 | 02:28 PM
cincyTT's Avatar
I'm make believe
Default RE: Been to the site, but Cant figure out ...how much the mod shack intake is!?
VTDA Pricing: (Specify engine and Color/finish. Shipped insulated unless uninsulated requested)
$10
Low Profile Engine bay trim for more sound and an 18 degree drop in engine compartment temps.Data here
$235
Brushed Stainless (26 gauge #4 finish) Picture here
$235
Polished Stainless (28 gauge 2B finish, polished) Picture here
$265
Translucent Powdercoat over polished stainless skin Red Blue
$265
Custom color matched paint w/clearcoat to your car like Lake silver or Moro Blue or Imola Yellow
$235
Custom powdercoated in various colors. Check the Color availability in the "Powdercoat Colors" album here
TTDA pricing details: (order a hose package below for a complete assembly)
Carbon group:
OUT
in Matte twill weave CF (black) Discontinued
OUT
in Gloss Twill weave CF (black) Discontinued
OUT
in MeTTalica in aluminum Metalized twill weave fiberglass (looks like Braided metal)Discontinued
Stainless group:
$260
in Brushed Stainless (T-304 overlay, 26 gauge, #4 brushed finish)
$260
in Polished Stainless, mirror finish stainless
Color match group:
$260
$275
in your choice of factory Audi colors over 28 gauge steel skin and clearcoated. Please supply Vin, Year, & Color code for Matching. Allow additional time for paint ordering, finishing etc. Like Misano Moro Blue or Amulet
$275
Translucent PC finish over polished stainless. Red Blue
New Options: (please specify when ordering)
+$25
Superinsulated TTDA: Adds a layer of high tech Koolmat to the inside of the tube (in addition to the Air/foil application.) This stuff is $$$. Good for a few more degrees of protection
+$20
2.5 ft. (simple install) Aeroduct hose (on left): Highest quality aircraft grade Neoprene hose. (2 pre-cut 15" hoses)
+$40
7 ft. (full install) Highest quality aircraft grade Neoprene hose. (single length for custom fitting)
Old Jan 9, 2007 | 02:31 PM
cincyTT's Avatar
I'm make believe
you can always make your own for really cheap, all you need is a filter, breather filter, and if you want to move it further away from the engine get a 2.75" coupler and strait pipe or 3" for 225's. Can be done for less than $50-60.
XCLR8TT's Avatar
Seems pretty simple to me... if you go to Modshack.info and click on the TTDA or VTDA links. If you look toward the bottom of those pages you'll see the pricing options below. There is some variability in the pricing based upon the configuration and options.
TTDA
Stainless group:
[ul][*]$260 in Brushed Stainless (T-304 overlay, 26 gauge, #4 brushed finish)[*]$260 in Polished Stainless, mirror finish stainless Color match group:[*]$260 Custom powdercoated in various colors. Check the Color availability in the "Powdercoat Colors" album here[*]$275 in your choice of factory Audi colors over 28 gauge steel skin and clearcoated. Please supply Vin, Year, & Color code for Matching. Allow additional time for paint ordering, finishing etc. Like Misano Moro Blue or Amulet[*]$275 Translucent PC finish over polished stainless. Red Blue[/ul] VTDA
[ul][*]$235 Brushed Stainless (26 gauge #4 finish) Picture here[*]$235 Polished Stainless (28 gauge 2B finish, polished) Picture here[*]$265 Translucent Powdercoat over polished stainless skin Red Blue[*]$265 Custom color matched paint w/clearcoat to your car like Lake silver or Moro Blue or Imola Yellow[*]$235 Custom powdercoated in various colors. Check the Color availability in the "Powdercoat Colors" album here[/ul]
Old Jan 9, 2007 | 03:22 PM
bmwtoaudi's Avatar
Im not the smartest person when it comes to cars.
I want the best modshack intake i can get, but i dont really understand what im buying and what kind of gains i'll see.
I dont care about color as its under my hood....
can one of you guys pick a intake for me? ...best proformance..etc
Also in that list there is a $10 part...that lowers your temp...what is that? where does it go? and will it really help?
Stock I have a 180 FWD TT
as of the 19th I would like to have the following done.
intake (modshack)
exhaust (borla)
APR chip (93 octaine)
stage one clutch
that VDA temp thing.
what kinds of hp/torque would you guess im running?
middle of december I would like to remove my k03 turbo with a k04 turbo
at that point what kind of hp/torque will I be running?
Thanks!!!!!!!!!!!!!!!!!!!
Old Jan 9, 2007 | 03:33 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: bmwtoaudi
Steve claims the vtda is better. You will see better throttle response but only a little increase in hp and torque
you get options just pick one you like best.
Im sure youll pick one out ok, all performance will be roughly equal
it looks like it just seals off the engine heat from the end of the intake
intake (modshack)
exhaust (borla)
stage one clutch
add a 3" down pipe and run 20-22psi and you should right around 200whp and 220-230 ftlbs
ko4-001 maybe 15hp more and 20-30ftlbs more and a ko4-2x alot 230-240whp and close to 300 ftlbs
Old Jan 9, 2007 | 03:41 PM
DenimTT's Avatar
The $10 piece is a pice of rubber trim for the driver side rear seal of the engine bay to the hood. You cut a pice of the thick stock rubber off and replace it with the thin rubber trim for $10. This allows some added cowl induction on the airbox side under the hood, which is good for an open element filter (such as the VTDA). Lower temperatures are never a bad thing though so I cut the stock strim off and just left the metal flange as is for the time being. The rubber piece is really just aesthetic, and you should be able to get it at most auto parts stores.
Old Jan 9, 2007 | 04:04 PM
BlackRaptor's Avatar
The VTDA Is a pretty good deal. the Neuspeed intake is only 30 bucks less and it's heat shield isn't as good on it.
Old Jan 9, 2007 | 05:50 PM
Palindari™'s Avatar
The FWD version of the TT came with the 180bhp 1.8T?
I thought it was a 150bhp 1.8? Didn't know it came that way...
Old Jan 9, 2007 | 06:13 PM
bmwtoaudi's Avatar
I'm going to come off REALLY dumb here, but I have to ask sometime,
what does BHP stand for? I hear it everywhere...and it just confuses me.
Thanks guys!
