blacked out grill badge
Old Jan 4, 2009 | 09:36 PM
warranty225cpe's Avatar
Thumbs up blacked out grill badge
So I did A little research before I did this, because I didnt wana tear anything up. I decided to go with that high temp engine enamel (the one with the engine on the can that has a bunch of high heat tolerance claims).I started with a light but thorough sanding of the emblem, then did a wipe down with some alcohol.. I must have sprayed at least 20 coats of this gloss black until all of the droplets of paint connected, and gave me a flawless shine. I took it to my buddies boddy shop, and wiped it down one last time to get all the grease and finger prints off of it. And just when I thought it couldnt look any better, he sprayed it with3 coats of clear. Then let it bake under the lights for a half hour. IMO the end result is perfect! I was debating on just painting it flat black, but Im glad I took the time to do it right. Thanks to clipse for the help. And yed, the reflector delete is gonna be next.
Old Jan 4, 2009 | 10:04 PM
lennyauditt's Avatar
Looks good! Love the rims! Are you going to do the back badge?
Old Jan 4, 2009 | 10:06 PM
l88m22vette's Avatar
Thats Batman's TT its so black ...you should have painted the rings yellow lol
Old Jan 4, 2009 | 10:50 PM
JPOS's Avatar
Member
Clear the heads, and that baby will look even better. Other than that it pretty much looks like teh sex.
Old Jan 4, 2009 | 10:56 PM
expelled's Avatar
car looks amazing! good job!
Old Jan 4, 2009 | 11:22 PM
Thanks. I'm gonna try to do the headlights and the back rings at the same time. Since they are getting painted the same color. Then Im having the tails and side signal markers tinted. All blacked out except the windows It doesn't get any cleaner!
Old Jan 4, 2009 | 11:32 PM
2Screwed's Avatar
Looks like we are going to have twins... to bad you are on the other coast, would make for a good photo shoot.
Old Jan 4, 2009 | 11:33 PM
Yellow break calips would be the sshhh*t
Old Jan 4, 2009 | 11:39 PM
Thumbs up
Ive decided on some black boxster calipers. Black is the only way to go IMO
Old Jan 4, 2009 | 11:42 PM
Are you running a 3.2 rear valance? and im gonna run spacers on mine. I left the 15mm in the front (sits perfectly flush with wheel well). but I need some 10mm,12mm, or 15mm for the back, because my 20mm were too big.
