boost gauge
ok, i figured out how mine all goes together and i also found out that you run the line behind the pedals. the only thing that i saw to tap into though was the FPR. is this possible. here is the link that i found.
http://public.fotki.com/blackfnTTruc...gauge_install/
no it not to the FPR= fuel pressure regulator. has nothing to do with the Turbo boost. check out this link he did one too not to the FPR at all.
http://www.loomknitting.com/auditt/
Jeff
Jeff
ORIGINAL: JewbinTT
Slowtruck I didnt think you put the turbo boost guage into the FPR. I thought it was suppose to go to Waste gate or the intercooler pipe to read boost pressure. Maybe Im wrong.
Jeff
Jeff
i had to rig up some brass connectors to make a T that i can use with the compression hose that i got with the gauge. i put everything together and i showed no boost at idle. when i put the revs up to 6000 it only said 5. if i used fittings that were to big would that be my problem.
ORIGINAL: slowtruck
Were you moving or just revving in neutral? The car has to be in gear with the engine under load to get boost, otherwise the waste gate stays open.
i returned the crappy guage this morning and got an auto meter pro comp. i think that i have a leaky intake gasket though. would that do it. and also driving the car i got it to spike at 7psi. what is the stock pressure on a 225?
