boost gauge
Hope I'm not too late to help. Heres the walkthrough I used.
Boost Gauge Wlakthrough
Looks like it could be an OEM gauge. If memory serves me, I used one of the vacuum/boost lines coming right off the DV. Good luck.
i hear somewhat of a ticking coming from the motor when it is running and my check engine light is on. the code was 1128 and it was not my MAF. do you think maybe it is my intake gasket and that is why i can only build about 6psi. i was on the LIE doing about 80 and i put the peddle to the floor and it would not go past 6psi and if i press the peddle the gauge wont move unless i have it to the floor. it also is not smooth at all, it just spikes from 0-6psi and back. there is no in between. here are some pics of the guage. not the best but they should give you an idea. i used the auto-meter pro comp.
http://i85.photobucket.com/albums/k7...8/DSCN0210.jpg
http://i85.photobucket.com/albums/k7...8/DSCN0209.jpg
ORIGINAL: slowtruck
slackerscott04
11
Feb 21, 2007 04:46 PM
s4me
May 18, 2005 08:39 PM
