Boost gauge on our stock instrument cluster
Old Jul 25, 2007 | 02:17 PM
auditt225's Avatar
Default Boost gauge on our stock instrument cluster
The other day I was scrolling through one of the audi forums and I saw that some had been able to put a boost gauge inside our instrument cluster. What I mean by the is the top part where it usually says tape or cd or FM, that part, he was able to show what boost he was at. Has anyone else done this? I will try to find the pic but it was awsome
Old Jul 25, 2007 | 02:19 PM
cincyTT's Avatar
I'm make believe
Default RE: Boost gauge on our stock instrument cluster
there are a few threads about it, someone on here bought it, but hasnt installed it yet.
Old Jul 25, 2007 | 02:54 PM
DurTTy's Avatar
funny enough, i was having a caht with a couple of audi guys, and they mentioned something about unlockign the computer to display the boost pressure on our instrument cluster.... they said somehting about flashing it with a programme. how one would do this i have no idea, i think its along the same lines. correct me if im wrong.
Old Jul 25, 2007 | 03:09 PM
.clipse's Avatar
SoCal Crew Member
^ that is possible. you need to flash a program that detects psi/hg and have the value display on the electronic display in the cluster. i'd write the program but... my C++ sucks =P
Old Jul 25, 2007 | 08:51 PM
achTTung's Avatar
Vag will read it, in like 4 different places (manifold, IC's, and some stuff I can't remember). I've run my laptop in the car to check boost pressure before. Suppose you could... if you feel like permanently attaching a laptop to the car.... feed it back out to an LCD display.
Old Jul 25, 2007 | 09:04 PM
cincyTT's Avatar
I'm make believe
Dont know why everyone is obsessed with this....Becca. If you want a digital readout and at real time get a Zeitronix ZT-2 Wideband Air/Fuel Ratio Meter.
It will do:
Input/Output range
Lambda
1.43 to 0.64 Wideband
AFR
21.0 to 9.5 Wideband
Vacuum
25.5 in Hg
Boost
25.5 PSI
EGT
200C to 1200C
Analog Wideband Output
0 - 5V
Throttle Position
0 -100 %
RPM
0 - 10,000
User Input
0 - 5V
Old Jul 25, 2007 | 09:08 PM
achTTung's Avatar
I'm doing it the hard way. Bought a Matrix Orbital vacuum florescent display, wiring it to a laptop, running vag, taking the info, sending to the VFD, and then projecting it thru a fresnel lens, off a mirror, and onto a piece of glass.
I'm stuck on the AR coating part, and the programming part. Any ideas?
Hoguenstein
Jan 19, 2009 09:38 PM
MK1audiTT
Apr 21, 2008 05:26 PM
Polivaris
Mar 29, 2007 02:58 AM
Wilco
Dec 12, 2006 04:40 AM
rock~1
Aug 8, 2006 04:59 AM
