Boost gauge questions
Yesterday I installed a Prosport boostgauge in my '01 225. It's stock (for now) other than a K&N drop in. Tapped in at the primary vacuum line off the mainfold. I notice that no boost registers when accelerating from 1stthrough 4th gear. The vacuum readings do decrease however. If I'm crusing along in 6th and step on it, or pull a hill, boost climbs and holds steady at 11psi. Is it normal that boost doesn't show otherwise?
Also, for the gauge mounting anyone have good options besides a vent ?(don't want to lose it's use) or cutting into the instrument panel. I picked up a single Apillar pod, but it'll need some significant trimming, paintingand forming. Even still, not sure I want the gauge there. I was thinking of cutting down the pillar pod to sit flat on the left corner of the dash. Maybe there's a nice steering column mount like a small pod or bracket? Any other suggestions?
I have been going through the same search on mounting options. I don't like look of the ventgauge and want a mount on the steering column like GTI's have. I called my APR guy and he said he'd be able to find one but I'm questioning if he reallycan. One option that is fairly reasonable is a VDO cup that you can get of egauges.com.
ORIGINAL: cincyTT
I have a mkiv steering columb mount in mine. fit is pretty good, and i can always have a good eye on things.
and you dont have to worry about pixel loss in that center display. [sm=goodidea.gif]
my 2000 w/ almost 100k on it has no pixel problems. lucky me. You can get those from tyrolsport.com and from a few other places for $35. Like i said fit is pretty good but is NOT perfect. But it works for me.
did you install it directly after the manifold? if not then check to see if you left one of those links in line with the hose. they are one way valves. the best place and easiest to hook it up is at the throttle body vacum or at the FPR, since it has a small line just like the boost gauge, and comes directly from the manifold
Not sure where mine is hooked into as a buddy of mine did it. However, I did have to replace a handful of vac line because Audi used a threaded line that fell apart.
Have you looked at the mount that replaces the ash tray?
