Boost Gauges, Boost Controlers, ETC...
Old Nov 24, 2007 | 02:50 AM
jojoenglish85's Avatar
Default Boost Gauges, Boost Controlers, ETC...
Im just wondering if anyone has a boost controler setup in their TT's because im wondering if its neccesary to even have one.
I have chiped my car and have a borla exhaust along with an aftermarket DV. im just wanting to know if its neccesary to get a boost control and which one to get will be better(electronic or manual???) Also is there any other electronics i should consider?
ps. If you have pics of your gauges and controlers then post up the pics, im trying to get a better idea of where to place them if i get any.
Old Nov 24, 2007 | 10:11 PM
Default RE: Boost Gauges, Boost Controlers, ETC...
come on guys, im needing this info.
Old Nov 25, 2007 | 05:31 AM
Murderface's Avatar
If you're chipped, you definitely want a gauge to see where you're spiking. Boost controller might make for more aggressive boost onset and higher spikes if you want to run more boost.
Old Nov 25, 2007 | 03:35 PM
thanks
Old Nov 25, 2007 | 03:55 PM
cincyTT's Avatar
I'm make believe
A boost controller isnt needed, but i wouldnt run w/o it personally. Youll spool faster (ball&spring) and hold boost longer (huge plus for a small turbo) with mbc. Also, you can help reduce huge spikes with changing loads with a mbc also (bleed valve style). So you can run either a ball&spring or bleed valve mbc, or better yet, one with both (turboXS hpbc).
There really isnt a need for a ebc unless you have a much larger turbo and want to control boost by gear/speed.
robb3457
Dec 9, 2008 12:34 AM
Wintermute
Nov 22, 2006 08:30 PM
2003silvervette
Jun 27, 2006 03:08 PM
audispeeddemon
Aug 27, 2005 04:10 AM
Skibos
Apr 15, 2005 03:47 PM
