boost leak?
Old Nov 18, 2007 | 03:05 PM
jakej's Avatar
Default boost leak?
Hello,
My 2001 225 stutters during heavy acceleration. I have a giac chip and the forge splitter. Is the stuttering due to a boost leak? I tried adjusting the dv, but it didn't help much (unless I need to crack it all the way to the maximum?)
If its a boost leak, what's an easy way to find the leak and where are the common leak points?
Thanks in advance!!!
Old Nov 18, 2007 | 03:35 PM
225tt's Avatar
Default RE: boost leak?
I bet your having the same problems I had....misfires or a bad coil pack. It wont throw codes, and its a pain the the *** to find out which one it is, unless you have vag-com....where are you located?
Old Nov 18, 2007 | 05:23 PM
cincyTT's Avatar
I'm make believe
how do you know if you have a boost leak? You would know immediatly if you had one if you had a boost gauge. Like said above, check or change your plugs and gap them correctly and get scanned.
Old Nov 18, 2007 | 05:24 PM
225tt's Avatar
ORIGINAL: jakej
Hello,
Haha thats a good one, umm everywhere!
Old Nov 18, 2007 | 07:51 PM
randomloginname's Avatar
Like was suggested, if you dont already, just get a boost gauge and make sure you are hitting boost you should be. If you still have the stock dv and it wasnt failing, you could, I believe, stick it back in temporarily to see if your problem is solved , though it doesnt sound like it will be. You could be running into TIP collapse to, perhaps. I dunno, good luck though. You can get a preesure tester, or pay to have that done as well, but I would go that route only if you have evidence that it isnt a firing problem, ie the plugs/packs.
Old Nov 18, 2007 | 08:20 PM
225tt's Avatar
Cause im a nice guy....
http://forums.vwvortex.com/zerothread?id=1605131
Old Nov 19, 2007 | 12:57 PM
jakej's Avatar
I bet it's the plugs. Now that I think about it, I changed the plugs right about the time the problem started. If that doesen't fix it, I'll get a boost gague.
Old Nov 19, 2007 | 09:16 PM
225tt's Avatar
Good idea!
Old Nov 21, 2007 | 02:43 PM
jakej's Avatar
The plugs were gapped too much. I reduced the gap to 0.028 and the problem was fixed. Thanks for your help!! I would have never guessed it.
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
