Boost and motor Mount Q
I finally got my boost prob fix but the boost is werid it goes to full sometime and other times it goes to 7 or 8 and theres a lag. And also i need a motor mount the one thats directly under the engine Is there a performance one or do i just got a stock mount?
The boost issue is all based on gearing and load, thats normal. As for the mounts, engine is on passenger side, tranny is on the driver and dogbone is underneith. You can get performace ones for all of them. You just need the 2 mounts and install them on the mount which takes about 20-30mins.
if u do dogbone make sure you push engine with your hands or feet to get it back aligned so u can bolt it back up undoing dogbone will push the engine forward(or backward lol cant remember)
