Boost "Pumping?" During Hard Accelleration
Old Sep 15, 2009 | 10:54 PM
neur0tic's Avatar
Default Boost "Pumping?" During Hard Accelleration
Hmm... Ok, so my car has been doing this for quite a while now... but my priority has been elsewhere for the last 6-8 months.
Anyhow... During hard acceleration (mostly in 3rd & 4th Gears) My boost will reach 21psi... but it kind of...
... pulses? Its hard to explain but it is NOT a smooth or consistant pull... its like it goes to 21psi... then drops to 18, then goes back up to 21psi, then back to 18.
I thought it was just a hole in a vacuum line or something that would only dump at higher pressure... but I cannot find a leak anywhere. Could this mean I should "Tune" my Diverter Valve? I'm still using the stock springs in my Forge D007 DV. I have the Tuning Springs and Shims...
Thoughts?
Old Sep 16, 2009 | 11:04 AM
joshuo's Avatar
I assume you're chipped from the 21 psi.
Your DV does indeed need to be tuned for the engine tune.
Old Sep 16, 2009 | 08:26 PM
beachchair's Avatar
Thoughts?
Don't know that changing your Spring/Shims will help your problem.....but try the Green Spring with 2 Shims. I'm chipped, and that combo works best for me.
billboos
May 1, 2009 12:10 PM
