BOV in need a few answers
Old Aug 28, 2008 | 09:37 PM
Blue01TT's Avatar
Default BOV in need a few answers
What do you guys use to plug the hole on the intake if you dont recirculate the bov? Also on my greddy type rs about what setting should it be on as far as hard or soft? Im not chipped yet but do have intake and exhaust if that matters,
Old Aug 28, 2008 | 10:02 PM
theTTkid's Avatar
i just went to home depot and rigged up a little plug... its not hard just go and look around, something will hit ya....
i would just tinker around with hard/soft until your happy with it
Old Aug 28, 2008 | 10:09 PM
Blue01TT's Avatar
okay well i got a small bolt with a large head so i could clamp it in there. Ill just play w/ the hard soft spring setting till i get it appreciate it
Old Aug 28, 2008 | 10:11 PM
theTTkid's Avatar
uh... i wouldnt use a bolt. MAKE SURE ITS TIGHT!!!! because if that bolt falls through its going right to your turbo... do the math
Old Aug 28, 2008 | 10:12 PM
theTTkid's Avatar
i got a drain plug that was threaded and wedge it in there then got a drain cap and capped it off btw
Old Aug 28, 2008 | 10:14 PM
Blue01TT's Avatar
oh no the head of the bolt is big with a welded on washer there is no way its gettin in that pipe
Old Aug 28, 2008 | 10:23 PM
theTTkid's Avatar
alrght just be sure of it... a dab of superglue may not hurt either, but yea, good luck broski
evelluser
Nov 5, 2012 04:41 PM
Phospro
Jun 19, 2011 09:15 PM
foley84
Dec 18, 2010 05:07 PM
Spunky_Wolf008
Feb 15, 2010 12:05 PM
zolensky
Dec 28, 2007 12:13 AM
