brake light flashes and beeps????? and a clunk
Old Jul 22, 2007 | 12:04 AM
carguytt987's Avatar
Default brake light flashes and beeps????? and a clunk
Noticed it a few times, everything seems to grab correctly (as in little wheel spin) now it seems to do it every time I take off hard, the Brake light flashes a few times and I get 2-3 beeps, same beep as low fuel. then it goes away till I launch hard again? any ideas? ALSO I noticed a clunk if i accelerate the let off gas hard the hit gas again "clunk"I would describe the sound like a bad u joint in a chevy truck? it seems to do it every time you:: on throttle ... off throttle,,, on throttle "clunk" Is that normal I never noticed it beforeI thought it might be play in Quattro portion, I did jack it up and the drive shaft doesnt seem to have play, I was playing around in a parking lot when I heard it, I was listining to the new Forge Splitter building pressure the letting it off . DAMN NEW BLOW OFF VALVE ...HA HA
Old Jul 22, 2007 | 12:07 AM
Default RE: brake light flashes and beeps????? and a clunk
Old Jul 22, 2007 | 04:39 PM
Any ideas?
Old Jul 22, 2007 | 04:41 PM
moeron7's Avatar
Mine does the same every so often. I just fill the brake fluid up and it goes away. I think I have a hydrolic leak somewhere with my clutch. Either my master or slave cylinder.
Old Jul 22, 2007 | 06:21 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: carguytt987
Noticed it a few times, everything seems to grab correctly (as in little wheel spin) now it seems to do it every time I take off hard, the Brake light flashes a few times and I get 2-3 beeps, same beep as low fuel. then it goes away till I launch hard again? any ideas? Brake fluid is low
Old May 18, 2010 | 01:07 PM
bradtom's Avatar
similar problem in my chevy duramax.
Old May 18, 2010 | 02:13 PM
SlackJaw's Avatar
...wat?
RainesTPCHANMN
Mar 18, 2014 05:15 AM
joeynach
Sep 30, 2009 02:00 AM
il laureato
Aug 18, 2009 11:41 AM
B5 owns
Oct 21, 2008 02:27 AM
