Brake Light LEDs
Old May 21, 2008 | 10:16 AM
randomloginname's Avatar
Default Brake Light LEDs
42dd has some push and turn led's, I need to replace some brake bulbs (obv. incandescent stock) and was curious whether anyone knew which I could use: BA9S, BAX9S, or the high intensity versions of either. For the corner smaller bulb, I am not sure whether its the mini wedge or the 194 for appropriate fitment. Probably going to go with red. Thanks
http://store.42draftdesigns.com/LED-Illumination_c_8.html
Old May 21, 2008 | 10:33 AM
theTTkid's Avatar
Default RE: Brake Light LEDs
...heads up, you posted this twice..
Old May 21, 2008 | 10:38 AM
[8D]yeah I noticed that, thanks. asked our loving mod to delete one
Old May 21, 2008 | 10:40 AM
.clipse's Avatar
SoCal Crew Member
in b4 delete!
Old May 22, 2008 | 01:55 PM
anyone? Thanks
Old May 22, 2008 | 06:20 PM
Palindari™'s Avatar
I tried LED brake lights - they don't draw enough current (which is a good thing) making the onboard think they are burnt out so it sounds a loud beep every freaking time you hit the brakes (which is a bad thing). [:@] Immediately took them out after 2 days of that nonsense...
As for the turn signals I don;t believe they are rigged the same way, but I have heard that due to the same low current req it fails to trip the blinking switch
good luck, mate!
Old May 22, 2008 | 09:19 PM
cmh's Avatar
cmh
The led BAX9S bulbs from 42 work fine in the front with no warning lights on the dash, I tested them but the yellow color didn't match so I ended up using the stock bulbs with orange silicone caps with my smoked OSIR lenses to match the stock side markers.
[IMG][/IMG]
kduznetsov
Feb 18, 2012 09:49 PM
randomloginname
May 21, 2008 10:16 AM
randomloginname
May 9, 2008 02:52 PM
