Brake and Turn, Parking LEDs
Old May 9, 2008 | 10:10 AM
randomloginname's Avatar
Default Brake and Turn, Parking LEDs
I asked 42dd about leds for brake lights and they said they werent able to help. Since I have such dark tails and am putting in the smked clear corners, Id like to get some yellow leds for the front parking and turn signals (so four total up front) and replace the 4 main bulbs in the tail light housing (that little side one is a pia, but id be willing to do that too), so 8 there. I have seen up on the forums the part numbers for incandescent bulb replacements, but didnt readily find any info for the leds I mentioned. Any ideas? Thanks
Old May 9, 2008 | 02:00 PM
Murderface's Avatar
Default RE: Brake and Turn, Parking LEDs
Superbrightleds.com has a lot of stuff but I really wouldn't recommend replacing your brake lights with single LED's. Notice that on factory cars with LED brake lights they have clusters with LOTS of LED's...one isn't giong to cut it. As for the parking lights/turn signals, H6W fitment LED's are hard to find. I know XXX1.8T found a set on Vortex, but I believe they're in Australia.
Also, if you want to use them for turn signals, you're going to have to get an extra relay type module since they won't draw enough current to make the relay blink properly...it might not work at all or it might blink double time.
Old May 9, 2008 | 02:52 PM
Bah...fair enough. I will leave well enough alone for now.
audiuser9
Jul 18, 2011 09:55 PM
kingman
Jun 5, 2008 10:00 AM
randomloginname
May 22, 2008 09:19 PM
randomloginname
May 21, 2008 10:16 AM
diehlryan
Feb 2, 2007 01:13 PM
