Brake Light Switch
Old Oct 26, 2009 | 09:44 PM
BMF!'s Avatar
Default Brake Light Switch
Anyone know how to change the brake light switch out? Got home tonight and the brake lights wouldn't shut off. i climbed under there with a flash light and messed with it a bit and it shut off temporarily.... I cant get my head under there far enough to see it. Guess I could get a mirror....
Old Oct 27, 2009 | 07:35 PM
achTTung's Avatar
removing the lower dash is a good start
never removed that switch but had the lower part off plenty of times. everything is easy access like that. Even your girlfriend!
Old Nov 3, 2009 | 03:26 PM
kwaskow's Avatar
I did mine a few months ago. the part is only $3 from the VW dealer. Easy to replace once you get the crud out of hte way. Quarter turn and pop it out. The new one is a different design and does not need to be "prepped" like the original either. Exact same conditions as yours, so I disconnected the battery - be sure you know your audio code
PennSt8_A4
Nov 28, 2012 09:47 PM
kwathom1
Jan 23, 2011 09:42 PM
brett83
Sep 9, 2010 02:47 PM
Dans99A6
Feb 17, 2010 10:38 PM
betes
Nov 5, 2008 08:27 PM
