Brake Lights
Old Dec 14, 2007 | 04:12 PM
moeron7's Avatar
Default RE: Brake Lights
Good idea. i will def. try to fix it any way i can without having to buy something. lol
Old Dec 14, 2007 | 04:17 PM
ugakage's Avatar
I feel I need to spend my 2 cents. I replaced my brake switch with a VW beatle brake switch (since there is no Audi dealership in Athens, GA) and it works great. Plus, it was only $4.
Old Dec 14, 2007 | 04:21 PM
moeron7's Avatar
Nice, i'm in Kennesaw. LOTS of friends in Athens. What are you driving now?
Old Dec 16, 2007 | 10:53 PM
ugakage's Avatar
2002 180 FWD. I just got it 3 weeks ago. Only 34k miles!
Old Dec 17, 2007 | 10:18 AM
moeron7's Avatar
OK, i got a new switch and then I broke it i think. Still doesnt work. My lights are always on now. Any idea's?
Old Dec 19, 2007 | 03:34 PM
ugakage's Avatar
Perhaps the plunger is stuck in the out position. I would remove the brake light fuse or unplug the switch to save your battery. I have another switch you can have. If you need help installing it, let me know.
Old Dec 19, 2007 | 03:41 PM
moeron7's Avatar
Yeah I do need help on the install. Any tips? I must be doing something wrong
Old Dec 19, 2007 | 03:53 PM
  #18
ugakage's Avatar
I assume you can get to the switch since you think you broke the last one.
When I installed mine, I didnt touch the brake pedal. I just made sure the new switch was not plugged in. Inserted it, rotated till it locked. Then plugged in the 4 pin connector. Tapped the pedal and saw red.
Try this DIY... It may be for a VW but it has some great pics.
http://forums.vwvortex.com/zerothread?id=1158315
Old Dec 19, 2007 | 04:01 PM
  #19
moeron7's Avatar
Yeah I pushed the pedal in and then inserted it but when let go of the pedal it pushed the thing all the way in and broke it. I just read this forum about a different switch that doesnt break, i may try and buy one of those. Check it out http://forums.audiworld.com/tt/msgs/1711363.phtml
Old Dec 19, 2007 | 04:11 PM
  #20
ugakage's Avatar
As I stated earlier, I used a VW Beatle switch. With this switch, you are able to install many different times to make sure you get it right. And again, only $4! I highly recommend it.
