brake pad wear indicator...
Old Jun 7, 2007 | 12:12 PM
ouTTie914's Avatar
Default RE: brake pad wear indicator...
ORIGINAL: LaTeShifTT
ORIGINAL: ouTTie914
I didn't put the cut wires together. Just snipped them as far down as I could, and called it a day.
By doing that you are creating fault in the system. The system thinks the brake pads are low and the warning light should be on all the time. Easier to take the time and just pigtail them together.
Only if you have a brake pad warning system... My car does not.
I was speaking of the connector from the new brake pads, not from the car.
Old Jun 7, 2007 | 11:57 PM
eliTTe's Avatar
i just cut them and twisted the 2 wires together, taped it up and it worked great.
Old Jun 8, 2007 | 12:44 PM
achTTung's Avatar
You don't have the brake pad indicator?
You have the weirdest TT of the forum.
Old Jun 8, 2007 | 01:56 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: achTTung
Not sure if that was a joke or not, but i dont have them either. Also by switching to wiloods, i would of had to get rid of them if i had them.
Old Jun 8, 2007 | 02:02 PM
techbod's Avatar
ORIGINAL: avant80@2.6
just don't use the witters or wires as I prefer to call them
you said witters I said wires and the result was good
Old Jun 8, 2007 | 02:06 PM
techbod's Avatar
ORIGINAL: theTTkid
so you have to connect the two witres that come off the pads??
actualy he did
Old Jun 8, 2007 | 02:08 PM
Vorais's Avatar
Yeah, I noticed that several of the TT's around don't have brake sensors. Reminding of which, I still need to figure out if mine does or doesn't.
hartsoe1
Aug 26, 2013 05:08 PM
hartsoe1
Apr 29, 2013 09:13 AM
domnf15
Sep 14, 2010 06:26 PM
yenkonova
Mar 21, 2009 02:50 PM
TT225R
Oct 6, 2006 07:44 PM
