Brakes
Does anyone have a problem with there brakes pads shifting in the rotors which makes a popping noise. Also i have hada awful brake squeal not the normal noise but it lower pitched and its loud. I have had the rotors replaced and i have had the turned the dealership says that audi normally make that noise and it will eventually go away. I have had this car since last october and it made the god awful since i bought it. Any suggestion on fixing the problem.[:@]
the noise is coming from the rear rotors
i have the same freakin problem!! Im going to get new slotted rotors cause i think mine are warped... then if that doesnt do the trick im going to throw on some green stuff pads... hopefully this will work
I used to have genuine audi pads brand new and my rotors were pretty crappy, I changed them to Hawk pads in the front, same problem - very very bad squealing. Yesterday i finally did my rotors (pep-boys specials
) Yu can't be hard on them right after you put them on,come to a stop very gently, let them set in, you'll be ok.
Spray the back of the padswith some brake quite. I had some poping in mine, but that was because my rotor wasnt fully fastened (stupid rotor screws, some know what i mean!). Fixed both on sat.now i just have some minor squeel from the high temp wilwood pads at low speeds on cold rotors from time to time.
