Brakes
Old Apr 22, 2007 | 04:54 AM
myrodhTT's Avatar
Default Brakes
Does anyone have a problem with there brakes pads shifting in the rotors which makes a popping noise. Also i have hada awful brake squeal not the normal noise but it lower pitched and its loud. I have had the rotors replaced and i have had the turned the dealership says that audi normally make that noise and it will eventually go away. I have had this car since last october and it made the god awful since i bought it. Any suggestion on fixing the problem.[:@]
the noise is coming from the rear rotors
Old Apr 23, 2007 | 02:00 AM
theTTkid's Avatar
Default RE: Brakes
i have the same freakin problem!! Im going to get new slotted rotors cause i think mine are warped... then if that doesnt do the trick im going to throw on some green stuff pads... hopefully this will work
Old Apr 23, 2007 | 02:31 PM
Creepin's Avatar
Default RE: Brakes
I used to have genuine audi pads brand new and my rotors were pretty crappy, I changed them to Hawk pads in the front, same problem - very very bad squealing. Yesterday i finally did my rotors (pep-boys specials) Yu can't be hard on them right after you put them on,come to a stop very gently, let them set in, you'll be ok.
Old Apr 23, 2007 | 02:42 PM
cincyTT's Avatar
I'm make believe
Default RE: Brakes
Spray the back of the padswith some brake quite. I had some poping in mine, but that was because my rotor wasnt fully fastened (stupid rotor screws, some know what i mean!). Fixed both on sat.now i just have some minor squeel from the high temp wilwood pads at low speeds on cold rotors from time to time.
Old Apr 23, 2007 | 08:43 PM
myrodhTT's Avatar
Default RE: Brakes
hey cincy so what your sayin is there is no way to get rid of this problem just deal with it right
Old Apr 23, 2007 | 08:45 PM
myrodhTT's Avatar
Default RE: Brakes
by the way i have already sprayed the back of the rotors with brake quite so what else do you suggest
Old Apr 24, 2007 | 02:00 AM
ouTTie914's Avatar
Default RE: Brakes
You sprayed the rotors with brake quiet????
Old Apr 24, 2007 | 02:37 AM
myrodhTT's Avatar
Default RE: Brakes
yeah i have
Old Apr 24, 2007 | 02:43 AM
cincyTT's Avatar
I'm make believe
Default RE: Brakes
it is suppost to go on the back of the pads. If your spraying the rotors, your gonna have some problems.
**so you have blue rotors now?
Old Apr 24, 2007 | 02:49 AM
ouTTie914's Avatar
Default RE: Brakes
They might be redish/orange depending on which brake quiet he used! [sm=lol.gif]
