BRAKES NOT AS THEY USED TO BE
Old Jan 21, 2008 | 04:26 PM
SCARBO's Avatar
Default BRAKES NOT AS THEY USED TO BE
HI EVERY ONE, NEED SOME HELP. I PEPLACED A PASSENGER SIDE REAR CALIPER ON MY 225
AUDI TT (99). I BLED ALL MY BRAKES THROUGH USINGTHE PRESURE BLEED METHOD WERE U PUMP UP PEDAL THEN RELEASE THE NIPPLE, THEN SAME AGAIN. PEDAL STILL SEEMS TO TRAVEL TO FAR TO FLOOR. IS THERE A SPECIAL WAY OR A CERTAIN SEQUENCE YOU HAVE TO DO IT IT . IF NOT ANY OTHERE IDEAS WHATS UP. ANY HELP WELCOME CHEERS [align=right][/align]
Old Jan 21, 2008 | 04:51 PM
MeanAudiA6's Avatar
Default RE: BRAKES NOT AS THEY USED TO BE
that method works well...where you adding fluid as you bled?...plenty if fluid still in the res?
Old Jan 21, 2008 | 05:54 PM
vegastt's Avatar
Pump and bleed works well. Caution should be taken as well.
Ihad to remove my calipers once and while I was bleeding the system my master brake cylinder went out.
I bought the car used and did brake work on it on the first week.
Im not saying that its going to happen its just some food for thought.
If they never feel right then your local brake shop shouldnt charge you more than 40 bucks.
Old Jan 21, 2008 | 06:55 PM
SCARBO's Avatar
ok what did your pedal feel like when master cylinder went down
Old Jan 22, 2008 | 06:59 PM
Smecker's Avatar
This is slightly off-topic, but how long do the brakes typically last before needing to be replaced?
Old Jan 22, 2008 | 08:49 PM
vegastt's Avatar
ORIGINAL: SCARBO
The pedal was pretty soft the only way it felt right to stop was to pump the brake pedal to bu ild up pressure.
The leak was big enough to allow air inside but small enough to allow pressure to build up.
Sorry for the late reply.
Smecker: Pads normally 30,000 rotors around 60,000.
Old Mar 11, 2008 | 10:37 AM
chosos's Avatar
What did the master cylinder repair cost you?
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
