Broke the ground on the coil pack..whats to do
Old Dec 20, 2006 | 06:39 PM
Pson's Avatar
Default Broke the ground on the coil pack..whats to do
Ok my buddy broke the ground off the coil pack on his TT. He solder the ground wire back but is there a better fix or having to replace the whole coil wires
Old Dec 20, 2006 | 07:19 PM
XCLR8TT's Avatar
Default RE: Broke the ground on the coil pack..whats to do
He broke the ground on the Coilpack? Or was it on the harness itself?
If it is the harness, probably best to replace it, they tend to fail over time from the heat.
I don't know if the harness p/n would be the same for your engine code. You need to find out.
Coilpack harness: 1J0971658L ($37 at worldimpex)
Coilpack harness heatshield: 8L9121659 ($44 at worldimpex)
"It's offically for a AWD Golf, but since the ATC engines are basically the same the harness fits perfectly. Install should be about 3-4 hours, getting the pins out of each of the connectors is the hardest part. I've attached
the TSB as well (has all the instructions)."
right click and save the Technical Bulletin
Old Dec 20, 2006 | 07:33 PM
Pson's Avatar
ORIGINAL: XCLR8TT
Thank you so much I can't think of how to really tell you hat I mean...lol. I have a V6 and its looks like the same thing on the TT. On mine the coil pack has a connecter one main piece (with tons of wires red , yellow the good stuff) and then a sigle black wire with a little black box which is the part that connects to the coil pack. That little black wire with the box is the wire that broke and he solder it just for the time being.
tj2k11
Jul 8, 2014 01:21 AM
mattavant
Sep 7, 2011 09:52 PM
7808
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
