broken dipstick tube
Old Jan 12, 2009 | 06:48 PM
ninjatturtle's Avatar
Member
Default broken dipstick tube
will a broken dipstick tube cause a vacuum leak code? immediately after i fixed the leak in the pcv tubing i noticed an increase in power. then slowly it started to decrease again. so today pulled off the bracket that holds the tube down and noticed it was broken near the bottom. i don't think it broke when i removed the bracket. the dealership quoted $9.84 for a new one i'll pick up tomorrow. for now i'll just superglue it and put it back on. should i get an oil change? there's no telling how much crap already got in my crankcase.
Old Jan 12, 2009 | 11:34 PM
XCLR8TT's Avatar
That tube isn't going to cause a vacuum leak. It is more than likely a hose that you either pulled loose another hose or you have a split somewhere. There is a quite often overlooked hose that has a sort of S shaped bend that connects to the bottom of your intake manifold on one end and to the PCV valve on the other.
Old Jan 14, 2009 | 12:02 AM
warranty225cpe's Avatar
Just did a patch job on a that hose. It was almost broken in half. Pressure is building and holding much better now.
Seertr
Jul 24, 2015 10:54 PM
pookeymp
Jan 4, 2015 07:17 PM
blairgrant
Mar 19, 2012 10:20 AM
Howlin_Mad
Aug 7, 2010 07:55 PM
TheHolyGhost
Jan 6, 2006 06:26 PM
