Broken Motor mount
Old Jun 13, 2008 | 04:30 AM
vegastt's Avatar
Default Broken Motor mount
This kinda is a rant.
Passenger side mount broke[:@][:@][:@][:@]
I thought it was my CV boot but I was wrong. The boot was ripped but because the axle was rubbing on the subframe.
After seeing that I got to thinking why. Well the frame wont move up on its own so that lead to checking the mounts.
Dogbones good Tran mounts good and I peak down at the motor mount and it looked normal but then I noticed it ws slightly misalligned.
The damn bolts sitting under the coolant tank, in half!
Thats about it now Im in talks with Issam for Density Line mounts.
A question I do have is- Would the dealer be my best bet on new bolts for my new mounts?
Thanks all.
Old Jun 13, 2008 | 05:07 AM
Wintermute's Avatar
Default RE: Broken Motor mount
They should have them in stock. Anytime they change out mount new bolts go in.
Old Jun 13, 2008 | 12:03 PM
cincyTT's Avatar
I'm make believe
Issam should be able to get you some also. ECS also has the available
Old Jun 13, 2008 | 01:38 PM
MeanAudiA6's Avatar
nope my dealer was out and so is ecs
Old Jun 13, 2008 | 01:56 PM
ouTTie914's Avatar
ORIGINAL: MeanAudiA6
Are you talking about these? ES#2201
Old Jun 13, 2008 | 03:29 PM
cincyTT's Avatar
I'm make believe
I have the set listed above from my engine build if someone needs them.
Old Jun 13, 2008 | 07:08 PM
MeanAudiA6's Avatar
thanks^ after i already them elsewhere paid 28 shipped for both sides....as they are different bolts
Old Jun 14, 2008 | 05:02 AM
vegastt's Avatar
Well the new mounts have been ordered and Im expecting them by Tuesday.
Ill check my dealer for the bolts, also getting a CV boot repair kit for my inner joint.
16v vw
Feb 17, 2011 10:51 AM
a4one
Aug 9, 2009 12:26 AM
edrocks3
Dec 9, 2008 10:11 AM
savagebeast
Jun 19, 2008 08:20 AM
audiboyy
Jan 22, 2008 11:34 PM
