Bumper or Suspensions
So, I had my front bumper cover worked on last week, and when I got the car back, there's a lot of squeaking noises when I drive over rough roads.
Do you think that the front bumper cover was improperly reattached or maybe my suspensions went bad?
Car has 65xxx miles 180 FWD
Well I'd start by visually inspecting the bumper. See if it lines up at the corners and around the headlights. Then I'd try to give the bumper a good wiggle to see if there's any play.
Any modifications done to the car?
Nope completely stock
I've applied pressure to the bumper and neither the bumper or suspensions make noise, but then again, I don't apply nearly as much force as the car does when it bounces around from bumpy roads
swaybar bushings are usually the first thing to look to when you have suspension squeaks. Soak the underside of the car with a hose. They tend to quiet down when they're wet, it'll let you know if thats the problem or not.
laoma
Jan 26, 2012 12:22 PM
