A/c
Old Jun 18, 2012 | 10:39 AM
ballamor's Avatar
Default A/c
My audi tt 2001 A/C goes on and off . Can any one tell the problem ?? pls!
Old Jun 18, 2012 | 02:29 PM
brrman's Avatar
Need more info, man. Explain what and when and how it is happening? Does it just blow warm, stop blowing altogether, etc...
Old Jun 19, 2012 | 07:52 AM
ballamor's Avatar
Default a/c problem
Hello guys
two days ago my a/c was working but for some reason it stop blowing cold air and it seems the fan is not spinning and the compressor is not genarating any cold air but all it does is blowing warm air..pls help ??
Old Jun 24, 2012 | 11:23 AM
fireman9585's Avatar
still not a lot of information to go on, but check the fuses on top of the battery. And cross your fingers. If one of those fuses is the problem, it will be your cheapest fix, although you will still have to find out what caused the fuse to blow.
Old Jun 24, 2012 | 11:39 AM
Dozanti's Avatar
It's possible from using it a lot this season, that one of the old orings on one of the high pressure lines has created a leak. Some refrigerant with the UV light leak detector and kit it comes with may come in handy for you. Check the fuses first though. This is one of those things sometimes its better to just spend a few bucks and have a shop that is reputable in this area do it for you. A/C systems can be a nightmare and become expensive to fix quickly
Old Jun 26, 2012 | 04:45 PM
tttracey's Avatar
hi my boyfriend has fixed both ac on our tt,s fuse box on top off battery open it first green 30amp fuse left hand side take it out check it clean it, over heats ,usual cause broken wires to rad fan or fan sensor on lower radiator or wire to the fan rely box all beside each other bottom off passenger side head light remove bottom cover also black bumper vent , get clear view ...if the fuse connections look bad when fuse removed link the wire on the fuse to the battery red plus but first check that wiring let me know ill pass info for you tttracey
