A/C Stopped Working
One day the A/C was working fine on my 2001 TT and then the next day nothing. The blower is working, but the compressor is not coming on. I checked fuse no 16 and those on top of the battery. What should I check next?
one: when was the last time you had it serviced? two: if fairly recent did they change the drier as well?
does any fan come on when you turn on the a/c?......
big loaded question with so many starts and tries.......
Ive used a few of those self R134 kits a couple years ago when mine needed a recharge and it worked well. Its only like $15 to diy and if that doesnt work, you need a new compressor. A good used one can be found on vwvortex.com for about $125-150 and takes about 1-2hr to install. There is also a how to on there as well.
Update....
If anyone cares. I took my Audi to the dealer. After some trouble shooting, they determined that it was a fuse box on the back side that was fried. It controlled the radiator fans, so the A/C wouldn't come on. With that replaced now everything is working fine.
Update....
Thanks
