Can I ask what a diode mod is?
Old Mar 16, 2007 | 11:07 PM
auditt225's Avatar
Default Can I ask what a diode mod is?
Can I ask what a diode mod is? Remember I'm a newbie! What performance gains do I get out of it, if ne?
Old Mar 16, 2007 | 11:37 PM
MeanAudiA6's Avatar
Default RE: Can I ask what a diode mod is?
read the FAQ will answer a lot of questions
Old Mar 17, 2007 | 02:19 AM
cincyTT's Avatar
I'm make believe
did i not answer your ?'s enough in pm or in my thread? I thought i was being very clear. If not please let me know.
Old Mar 17, 2007 | 02:25 AM
munkee's Avatar
what does the diode mod do again?
Old Mar 17, 2007 | 02:36 AM
cincyTT's Avatar
I'm make believe
a diode limits the voltage from the map to the ecu. The higher the volts the higher the psi. The 4.3v limits the ecu to only seeing 11psi, the 4.7v limits the ecu to 17psi (for a chipped car it you are having trouble hitting limp) and the highest the ecu can read is 5v. So if you have no chip and want to increase the psi you need a 4.3v so it only lets the ecu see 11psi (which @14.7 you will hit limp) and then turn up the boost. For some chips, the tune is to aggressive and you may hit limp from time to time above 17psi. So by limiting the ecu to only see 17psi you can then run the boost up to 20-24psi with ease.
*** 225tt. will you please insert this and link the other thread into the faq (like anyone looks) please.***
Old Mar 17, 2007 | 02:38 AM
ouTTie914's Avatar
ORIGINAL: cincyTT
a diode limits the voltage from the map to the ecu. The higher the volts the higher the psi. The 4.3v limits the ecu to only seeing 11psi, the 4.7v limits the ecu to 17psi (for a chipped car it you are having trouble hitting limp) and the highes the ecu can read is 5v. So if you have no chip and want to increase the psi you need a 4.3v so it only lets the ecu see 11psi (which @14.7 you will hit limp) and then turn up the boost. For some chips, the tune is to aggressive and you may hit limp from time to time above 17psi. So by limiting the ecu to only see 17psi you can then run the boost up to 20-24psi with ease.
Uhh... I think the monkey was being facetious.
Old Mar 17, 2007 | 02:45 AM
munkee's Avatar
i was... sorry guys...[edit]... and gals. [:@]
Old Mar 17, 2007 | 02:51 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: munkee
i was... sorry guys.[:@]
it wasnt you, im just sick of answering the same questions in differnt mediums of communication. More so if its by the same person.
Old Mar 17, 2007 | 02:54 AM
munkee's Avatar
instead of having a sticky named " FAQ AND BASIC TT INFO ", perhaps we should make a whole seperate one named, " MOD FAQ "
granted, if most people skip past the original "FAQ", who's to say they'd stumble into the suggested?
just my .02
Old Oct 14, 2007 | 08:26 AM
tom1222's Avatar
Good Idea Munkee. Who wants to read a boring FAQ and Basic TT crap. Modding FAQ sounds a lot more exciting! [8D]
CCA4
Feb 7, 2011 09:07 AM
Mevans607
Feb 4, 2008 04:09 PM
1.8TK3MP
Jan 24, 2008 10:41 PM
Red_sapphire89
Jan 15, 2008 03:09 PM
CJRando
Oct 21, 2007 04:51 PM
