Chains on a TT?
Old Nov 29, 2007 | 12:18 PM
Smecker's Avatar
Default Chains on a TT?
Has anyone ever put chains on their TT? Is it even possible? I have the stock fat 5s. I'll likely be going over the pass a bit this winter, but I don't know if the conditions will be bad enough often enough to warrant getting snow tires. Should I just break down and get a set of snow tires?
Old Nov 29, 2007 | 01:39 PM
theTTkid's Avatar
Default RE: Chains on a TT?
Im assuming you have summers and not all seasons...
If it snows where you are snow tires would be a good idea. I wouldnt recommend chains but thats just me
Old Nov 29, 2007 | 01:41 PM
cincyTT's Avatar
I'm make believe
good allseasons should be good enough unless your in a place that sees very high amount of snow, then a low TT shouldnt be driven
Old Nov 30, 2007 | 09:05 AM
sttjackett's Avatar
don't put chains on unless you must. the sway bar links could get damaged by the chains. a good set of snows is worth the money,
Old Nov 30, 2007 | 05:21 PM
jakej's Avatar
chains ona TT? It's a sports car...
Old Dec 20, 2007 | 09:52 PM
seinsmeld13's Avatar
Actually they are now called winter tires, as they are designed for cold weather below 7 celcius or about 39 farenheitnot just for snow. I am in southern Ontario and have a set of 4 on mine. The car is geat in the snow with proper tires. I use summer tread from April until the end of October.
Old Dec 22, 2007 | 01:31 PM
Mininger's Avatar
ORIGINAL: sttjackett
X2
ptowndvldg
Dec 8, 2009 01:18 AM
pazo
B8 Models
Mar 13, 2009 12:20 PM
superdooperme
Dec 25, 2008 01:34 PM
lbraasch
Dec 13, 2006 04:03 AM
kurtanaudiguy_maybe
May 11, 2006 11:44 PM
