chips
Doritos are really good. I like them a lot. If you eat them and don't exercise regularly, expect to see gains between 5-15 pounds a month.
*SEARCH*
*SEARCH*
First off, please search there is a TON of information of different chips and software. Also do you have a 180 or 225 TT? What are your goals for the car? Do you want to go with a Bit Turbo setup or do you want to max out your stock turbo? Unitronic is a great company, GIAC, APR, REVO, Eurodyne; they are all good reputable companies.
I would look to see if you have any local dealers for any of those companies, local support is always a good thing. If you do not have any local dealers you can ship your ECU to the company of your choice and have them flash/chip it and send it back to you.
unitronic runs 26 psi out of the k04. Higher boost then any one else. but boost is only one small factor. timing maps and correction maps are all perfectly tuned so the car pulls very hard through redline. if you want i can chip and ship your ecu.
