chugging noise
Old Jul 30, 2008 | 11:51 PM
DEDMN_TT's Avatar
Default RE: chugging noise
I have a 01 FWD 180 and the boost peaks at 20 sometimes too but I've been assured that's normal. I've had two things fixed before that has somewhat similar symptioms... Coil pack maybe or a belt tensioner... see what the others think.
Old Jul 31, 2008 | 12:01 AM
jhsoccerodp's Avatar
timing belt was just done along with all acc so its not a tensioner and also, it doesnt really just jump to that. it nromally gets up to there and flutters at like 19-21psi when floored.
Old Jul 31, 2008 | 01:13 AM
GHETTOxWHITExBOY's Avatar
do you accelerate smoothly if you press the pedal slow and when you gun it the whole car jerks/twitches around 3500-4000 ? if so i'd check the plugs and coils, had the same problem.
also if your gettin 20 psi or higher its gotta be chipped !!! good luck !!!
Old Jul 31, 2008 | 10:11 AM
would it hurt anything to run the 28 gap vs 32
Old Jul 31, 2008 | 12:31 PM
burner5's Avatar
Member
Is there a cel on? If so, definately check that. I've had the same symptoms simply from plugs. And after i changed them, There was no reoccurance. Ahh the fun in troubleshooting
Old Jul 31, 2008 | 04:50 PM
well it seems to be more of a fluttering noise.
Old Jul 31, 2008 | 11:35 PM
ghetto, did you have a cel, i didnt and also was it a fluttering sound or did it just bog down
Old Aug 1, 2008 | 12:06 AM
  #18
theTTkid's Avatar
20 psi... must be chipped... and since you didnt know about it id start by regapping the plugs
Old Aug 1, 2008 | 12:11 AM
  #19
does it have ti be chipped? I will take a video of the boost gauge tomorrow to show what it does
declanrafferty
Feb 27, 2015 03:53 PM
phatjames167
Dec 28, 2012 10:55 AM
Dennisyudich
Oct 18, 2012 06:32 PM
e8917t
Sep 1, 2009 02:42 PM
beaver
Mar 18, 2005 07:14 AM
