cluster - temp warning? - huh?
Old Aug 27, 2007 | 05:11 PM
bmwtoaudi's Avatar
Default cluster - temp warning? - huh?
I was driving back to the office today, and my cluster had a thing that looked like a music note pop up on the center console. - it had waves going through it. - Temp? - Thing is ...it did it for about 3 blocks...I opened my door and shut it... wondering if it was that...it went away and the beeping stopped.
What could this have been? - Just another TT alien? - Or could I be replacing a sensor?
Old Aug 27, 2007 | 05:20 PM
cincyTT's Avatar
I'm make believe
Default RE: cluster - temp warning? - huh?
Low on coolent. Sometimes it reads below the min line and then will go away. Check the fluid level, you may just need to top off the level with distilled water.
Old Aug 27, 2007 | 05:21 PM
bmwtoaudi's Avatar
Our weather here has been going up and down (I live in the mid-west) - I'm assuming due to the nature of the beast (90F) - mid day - and (60F) - In the morning will throw some things off.
Old Aug 27, 2007 | 05:23 PM
cincyTT's Avatar
I'm make believe
shouldnt, im sure its just the fluid levels since you didnt say it overheated.
Old Aug 27, 2007 | 05:47 PM
ouTTie914's Avatar
Yeah like cincy said just check the coolant overflow tank and make sure she's up to par.
That happened to me one bitter cold winter morning. As she heated up, and the fluid expanded everything was fine.
Old Aug 27, 2007 | 07:50 PM
bmwtoaudi's Avatar
she didn't give me any guff on the way home 40 miles...im sure im fine. YAY!
Old Aug 27, 2007 | 07:52 PM
cincyTT's Avatar
I'm make believe
have you even checked the level yet?
Old Aug 27, 2007 | 08:04 PM
diehlryan's Avatar
ORIGINAL: cincyTT
probably not.. you have to pop the hood to do that.
Old Aug 27, 2007 | 09:12 PM
bmwtoaudi's Avatar
Are you implying I dont pop my hood?
Old Aug 27, 2007 | 09:16 PM
cincyTT's Avatar
I'm make believe
Most of the time i doubt it.
