Clutch issues.
Hello ,I have a 2000 Audi tt quattro mk1 6 speed 225hp we had a broken shift fork we replaced. We put in a new clutch and slave cylinder bleed the system. The issue is that you can not put the car in gear while running. Only when the car is off will it go into gear. We start the car while in gear and it moves just slightly at first we let out the clutch and it will move forward as normal push clutch back in and still cannot shift to any gear or out of gear. Correct advise would be greatly appreciated. Thanks.
