Collapsing quorstion!
Old Apr 25, 2007 | 03:26 PM
joshuo's Avatar
Default Collapsing quorstion!
Hi
I read about the collapsing TIH when you get a TT chipped. does this affect both engines?
i saw that alot of people have a samco hose to prevent it.
my question is, if i chip my car and get a less restrictive intake (like a VTDA), will that get rid of the collapsing problem as well?
(makes sense, more airflow = lower pressure difference between the air outside and inside the tube = no collapsing?)
thanks.
Old Apr 25, 2007 | 03:49 PM
cincyTT's Avatar
I'm make believe
Default RE: Collapsing quorstion!
the only thing that will stop the collapsing is a new tip. The stock 225 is all hose, and it collapses. An aftermarket silicon one is much stronger and will not collapse. www.Forgemotorsport.co.ukhas a vid on the site of it happening. Replace it and you will be good to go.
Old Apr 25, 2007 | 03:56 PM
twenty8red's Avatar
i put a forge tip (same as samco)on my 180ttq and noticed a nice difference in the higher rpm range.
Old Apr 25, 2007 | 04:00 PM
cincyTT's Avatar
I'm make believe
before anyone asks, the 180's have a 2 peice intake and will not have collapsing, if you do swap it out, you will see better and smoother flow. 225's need them to prevent/correct collapsing and increase airflow.
Old Apr 25, 2007 | 07:01 PM
Ergokinetics's Avatar
TTStuff.com says that the hose fits2001-2002 models with ESP. What about those of us without ESP or for the 2003+ cars?
Old Apr 25, 2007 | 07:33 PM
joshuo's Avatar
is it hard to install them? i heard people are having trouble with DIY's on this.
Old Apr 25, 2007 | 07:44 PM
twenty8red's Avatar
it was a little tough. i did the complete install from above the engine. would have been much easier from below or if i had really small hands.
Old Apr 25, 2007 | 08:34 PM
MeanAudiA6's Avatar
yeah its not that easy.....its almost impossible to keep from cutting the stock hose to get it off. other than that...you shouldnt have a problem
Old Apr 25, 2007 | 11:10 PM
joshuo's Avatar
dont really care about the stock hose...
you dont have to cut the new one to get it on right? [&:]
Old Apr 26, 2007 | 12:52 AM
MeanAudiA6's Avatar
no you dont have to cut it
