conrtol arm bushings
Old Jun 12, 2008 | 10:14 PM
kevintt's Avatar
Default conrtol arm bushings
im no ase or anything, although over bumps and when shifting in to gear and releasing clutch theres a bang noise. the bushings way over due. if you take a lug wrentch and go to tighten the lugs the wheel moves up and you can see the control arm hit the metal under the car. The parts say bonded, so i take it they might have to be pressed in to the control arm. anyone do this, and any advice??
Old Jun 13, 2008 | 01:03 AM
kevintt's Avatar
Default RE: conrtol arm bushings
never mind found a how to, any one know what to lube it with, and my abs speed ring got dropped b the ******* who put in my wheel bearing. denting it. and now my abs lights on. where other then than the aud stealer can i get a reacement??
Old Jun 14, 2008 | 11:34 AM
achTTung's Avatar
abs ring is welded on. you can't replace just that, the whole hub assembly needs to be replaced. Might wanna try a salvage yard. everybody loves shokan.com
tianarhadoo
Jun 22, 2010 01:13 AM
copper07
Oct 26, 2009 09:17 PM
InExile
Apr 14, 2007 02:07 AM
Audi_Skydiver
Mar 15, 2007 02:18 PM
luvin_the_rings
Dec 14, 2005 11:09 PM
