Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Bushings worn out
Old May 23, 2010 | 10:48 PM
tianarhadoo's Avatar
Question Bushings worn out
hi everyone, this is the first time I get online to get some answers for my car... I have an 02 A6 3.0 for almost 3 years now and this is my first major problem that I experienced so far. Besides that anything works great. I looked under the car and it seems that my bushings are worn out.
My question is; can I replace just the bushing or I'm better off buying the Control Arms Kit and replace everything?
This would be what I found online so far http://www.fcpgroton.com/product-exe...ategory_id/181
It seems that my motor mounts are going bad too, are they hard to replace?
Old May 26, 2010 | 09:57 AM
Mike-2ptzero's Avatar
Engine mounts are not all that hard to replace and you need to buy the control arms.
Old May 27, 2010 | 11:21 PM
Thank you, but unfortunatelly I already bought the bushings, would you think they're hard to change and use the same control arms?
Old Jun 1, 2010 | 10:03 PM
vtraudt's Avatar
Default Upper (?) Control arms A4 B5
[quote=tianarhadoo;1209150]I have an 02 A6 3.0 for almost 3 years now and this is my first major problem that I experienced so far. It seems that my bushings are worn out.
/quote]
My car is a 1998 A4 1.8T quattro (B5).
I had my car on the hoist and check out the 'clonking' noise coming from the front. It looks like my upper (at least) control arms are worn. I can wiggle the passenger side wheel quite a bit, the driver side also (a bit less).
What are my options?
- has anyone used the kit shown in above link? Are they any good?
- other kits?
- just the upper arms with bushings?
- just the upper arm busings?
Can some post link to instruction how to do the work?
Thanks.
Old Jun 22, 2010 | 01:13 AM
sandy's Avatar
Do some online research and pick up the entire A-arm assembly (including bushes) and either replace them.
vtraudt
May 16, 2011 04:25 PM
waveblaster200
Jul 21, 2007 02:10 AM
SAudi
May 10, 2007 09:07 PM
mandkole
Mar 9, 2007 11:32 PM
16w/A4
Jul 22, 2006 12:36 PM
