coolant leak
Old Jul 11, 2008 | 08:11 PM
jhsoccerodp's Avatar
Default coolant leak
here is a picture of the small puddle of coolant i have found on my engine, i first noticed it when i smell something sweet everytime i get out of the car. My guess is a hose or fitting, any input would be great here are some pictures.
Size:  44.6 KBName:  IMG_0508.jpg
Old Jul 11, 2008 | 08:45 PM
achTTung's Avatar
Default RE: coolant leak
Theres 2 hoses leading to/from your oil filter plate that run around that general area. not much to say about it though, if you have a leak, find the leaky hose, replace/fix it. Any more specific question about it?
Old Jul 11, 2008 | 08:51 PM
any ideas to help find the leaking hose?
Old Jul 11, 2008 | 10:20 PM
vegastt's Avatar
I suggest checking the temp sensor line. You could have a small tear that lets the water travel as you move.
Old Jul 12, 2008 | 12:37 AM
does anyone know which of these hoses is coolant hose or could chop the picture and repaste it just marking which hoses are coolant.
Old Jul 12, 2008 | 09:01 AM
indeed the leak is coming from where the temperature sensor is does anyone know the part number for vw or audi or where i can buy that plastice piece that the sensor sits into?
is it this?
http://www.ecstuning.com/stage/edpd/...tegory=Cooling
go to coolant hose flange.
Old Jul 12, 2008 | 12:32 PM
XCLR8TT's Avatar
Yes, that is the right piece.
Old Jul 12, 2008 | 03:26 PM
is that piece hard to replace? and also i will be doing the timing belt at the same time as preventive maintenance.
Old Jul 12, 2008 | 09:55 PM
Art138's Avatar
It is the coolant plastic hose connector 0 ring. I am changing mine as we speak. Problem you can not find the 0 ring.....must buy the complete part. Go to rockauto.com part#06A121132Qand it costs 8.92. Very reasonable. I thought the leak was from a lower hose and changed it. Finally an audi mechanic told me that at about 80 thousand miles the 0 rings degrade on the hose connector. I am waiting to get the part to install. Not hard just messy. suggest you drain the coolant because when you pull the hose connector from the blockthe coolant pours out. If you need guidance PM me>......
Old Jul 12, 2008 | 10:04 PM
you could have just ordered the oring from the site i listed, it had only that fro like a dollar, i ended up ordering the whole thing and then the green sensor since i still had the black one, anyone have tips on instal and also will be doing timing belt
