Coolant temp sensor is loose
Old Mar 21, 2007 | 10:07 PM
bcart82's Avatar
Default Coolant temp sensor is loose
I'm sorry for all the somewhat lame posts...I do search, but I can't find what I need...
I just replaced the coolant temp sensor (code P1296 told me to ) and when I reinstalled it I noticed it was "loose" I could wiggle it a bit...I installed it about 3 times to make sure the o ring seated properly and the clip was all the way in...With the engine running I wiggled it a lot, no leaks or problems...
So the question is... Is it supposed to feel this way? Will it get "tighter" after pressure builds up from a hot engine?? Please help quick, I don't want to spill coolant all over the freeway tonight!!! TIA!!
Old Mar 21, 2007 | 10:13 PM
XCLR8TT's Avatar
Default RE: Coolant temp sensor is loose
It will be fine. The O-ring will keep the seal.
Old Mar 21, 2007 | 10:14 PM
diehlryan's Avatar
No.. Ithnkits supposed to be a fairly solid fit. Mine is not shaky at all. Did you make sure the old o-ring was removed too?The temp sensor sittingon 2 o-rings might be the problem.
Old Mar 21, 2007 | 10:25 PM
bcart82's Avatar
yupp, old o ring is out.
The sensor is definately below the plastic clip...I'm wondering if i should try a test drive or not...
Old Mar 21, 2007 | 10:57 PM
diehlryan's Avatar
Steve knows his stuff. Should be good.
Old Mar 21, 2007 | 11:14 PM
bcart82's Avatar
just took it for a couple miles, got it to running temp. No leaks what-so-ever, and the sensor is rock solid now...I guess the back pressure finishes the seating of the o-ring.
Thanks for the help in the time of panic!
I think this may be the best forum i've belonged to yet...the search works, the folks are friendly, and every post isn't about neon pedals or dream catcher air freshners.
diafolwrecsam
Jul 8, 2013 02:16 PM
bettysdad
Oct 15, 2009 10:18 AM
phillfriend
Mar 14, 2007 02:31 AM
