Del RIO Big turbo upgrade
Old May 10, 2007 | 05:26 PM
Blown87camaro's Avatar
Default Del RIO Big turbo upgrade
Well heres a question.... Have any of you installed or have the del rio system....My local Guy can get the package for 5k.. It uses the Gt28rs turbo......Isnt this the same turbo as the APR kit?. So 375+ hp with this kit?
Old May 10, 2007 | 05:40 PM
cincyTT's Avatar
I'm make believe
Default RE: Del RIO Big turbo upgrade
The 225 kit is a 2871r .86, apr kit use a .64. They use a giac tune that is just as good as the apr tune. You can look up m this 1 on vortex, he uses one and make good numbers. He was one of the first to get and use the kit.
Old May 10, 2007 | 05:45 PM
cincyTT's Avatar
I'm make believe
Old May 10, 2007 | 06:17 PM
?? The Del rio web site says for 225hp audi model.... The basic kit includes:........................... -Exhaust manifold................................... -GT28RS hardware for ballbearing turbo................... -Stainless steel downpipe.................... -Aluminum tubing................................... -Silicone hoses....................................... -Oil and water fitting................................ -All installation
Old May 10, 2007 | 06:28 PM
cincyTT's Avatar
I'm make believe
They changed it, I promise. They have never updated the website, why, i dont know. It is a gt2871r with a .86 turbine (to keep stock internals).
Old May 10, 2007 | 06:43 PM
MeanAudiA6's Avatar
the gt2871r is a nice turbo anyway thats the one i'll be going with most likely..
Old May 10, 2007 | 09:19 PM
So whats the hp limit on the 225 before i need to start worrying about rods... 400 crank hp? Id like to see some track times with this kit....I would hjope for the money you should be deep into the 12's
Old May 10, 2007 | 09:29 PM
cincyTT's Avatar
I'm make believe
its not hp you have to worry about, its low end torque. People are making almost 400whp on the 2871r w/ .86 turbine and stock internals (2000 atc engine 38Xwhp) and many with t3t4 50 trims. These both have smoother powerbands and push peak torque further out in the rpms. I have seen people blow rods through blocks with 28r's and 2871r's w/ .64 turbines. 300-350ftlbs usually is the limit people are willing to push on stock rods, depending on turbos.
You should be easily in the 12's and knocking on 11's with some slicks and a haldex controller.
5Speedwtneed
Nov 2, 2010 10:44 AM
Cpark07
Jul 12, 2008 04:24 PM
ocielz
Oct 18, 2007 05:40 PM
ocielz
Oct 18, 2007 05:16 PM
ocielz
Aug 3, 2006 03:29 PM
