diode and 4 bar
Old May 15, 2008 | 11:25 PM
Dfminc's Avatar
Default diode and 4 bar
So if a 4 bar fpr is used to provide more fuel for higher boost made possible by a diode and mbc won't the car run rich under normal cirucumstances? Sorry for the run-on...
Old May 16, 2008 | 12:11 AM
Audi858's Avatar
Default RE: diode and 4 bar
This is what I got out of a FWD 1.8t, with diode, fmic, MBC, forge 007, stage 2 clutch light weight flywheel, and about 15psi.
https://www.audiforums.com/m_847631/tm.htm
Old May 16, 2008 | 01:13 AM
Dfminc's Avatar
nice numbers
Old May 16, 2008 | 05:45 PM
cincyTT's Avatar
I'm make believe
The injectors will push more fuel when needed, you have nothing to worry about
Old May 16, 2008 | 09:45 PM
Dfminc's Avatar
Youll get the extra fuel for higher boost but I was doing some research and the 4 bar pushes more fuel than the ecu has the ability to compensate for. So at idle or something won't the car be running rich?
Old May 16, 2008 | 09:48 PM
cincyTT's Avatar
I'm make believe
the injectors will compensate and the duration they are open will be less. The a/f will be good in all rpms
CCA4
Feb 7, 2011 09:07 AM
Mevans607
Feb 4, 2008 04:09 PM
1.8TK3MP
Jan 24, 2008 10:41 PM
Red_sapphire89
Jan 15, 2008 03:09 PM
CJRando
Oct 21, 2007 04:51 PM
