DIY turbo removal/install
Old Oct 24, 2008 | 03:42 AM
vegastt's Avatar
Default DIY turbo removal/install
I need some help on finding a DIY for a turbo removal.
I have a K03s sitting in the garage and I think my turbos about shot.
Old Oct 24, 2008 | 02:04 PM
TurboTT920's Avatar
not too hard...Basically you are just gonna do a straight swap correct? Unbolt the downpipe, take off the tubo inlet and turbo outlet hoses, the hose going to the wastegate, and depending whether you are putting new oil and coolant lines on or reusing your current ones will determine the next step. Either unbolt all four lines from the turbo or if you are replacing the lines just unbolt/unclip all four from the block/oil pan. After that the only thing holding the turbo on are the three bolts that go to the manifold...then swap and reverse the steps...there are threads about this on other forums for sure with pics. Good Luck
Old Oct 24, 2008 | 07:09 PM
vegastt's Avatar
I checked vortex with not much luck, still need to give a more extensive search.
I also want to check my exhaust manifold for any cracks I was hearing exhaust leak for awhile, then I got in to fight with my car against a fence... the fence won :-)
I had a pole wedged in between the subframe and underbody I could tell that it hit the down pipe but I couldn't find anything.
Thanks for the input.
Old Oct 24, 2008 | 07:47 PM
TurboTT920's Avatar
Here is a link to one for a jetta 1.8t...this link is for swapping to a K04 from a K03 but the jetta engine bay nad your engine bay is the same...At least te pics here will help you as far as location and more of a step by step. http://forums.vwvortex.com/zerothread?id=3562254
Old Oct 25, 2008 | 02:44 PM
Mobius97's Avatar
Thats a nice link.....makes me wonder about the folks who bought those cheap Ebay downpipes, but that one was from GHL. Did ya'll see that flex section?
Old Oct 25, 2008 | 05:55 PM
vegastt's Avatar
Great link that helps out a lot!
The flex pipe seems really small.
rallyrcr150
Sep 13, 2008 09:23 AM
roostboost
B7 Models
Apr 20, 2008 08:54 AM
boost_junkie
Mar 13, 2008 01:45 AM
audi_n00b
Jan 30, 2008 12:31 AM
lidonnit
Jul 27, 2005 08:29 PM
