Dogdone mount project failed
Old Mar 7, 2009 | 09:54 PM
JaceTun's Avatar
Thumbs down Dogdone mount project failed
I finally gathered all my courage and laziness tried to change my dog bone bushing today.
spent a few minutes jacked up the car and removed the lower splash guard.
There goes the dog bone. I grabbed my 14mm socket ready to tackle this sucker, and I found out that I can't get the bolt to loose. Messed around for an hour, then decided to give up.
I ended up changed one of my clamp of my FMIC hosing. At least I got something done.
BIG FAILURE
Old Mar 7, 2009 | 10:23 PM
l88m22vette's Avatar
Uh, turn your ratchet?
Old Mar 7, 2009 | 11:21 PM
warranty225cpe's Avatar
Some times you have to put some *** into it. Use a cheater pipe and get your wait on it. Be a man!! LOL. Cheater pipe should work.
Old Mar 8, 2009 | 01:10 AM
bvnguyen516's Avatar
also, do you have a jack with a piece of wood under your engine, there could be extra vertical tension because of the engine pushing down. but also i would agree and dont take offense to it. just turn the ratchet
Old Mar 8, 2009 | 01:18 AM
Mobius97's Avatar
Soak that bastard in some PB Blaster and let it sit for a bit. Be careful
Using a cheater bar you don't want to completely force it and snap of the head of the bolt.
Old Mar 8, 2009 | 10:20 AM
jakej's Avatar
The same thing happend to me a few times. The bolts just would not come out. The best way is to use an impact wrench. Otherwise PB blaster helps a lot too. I suggest looking into a impact wrench though... one of the best tools I bought.
Old Mar 10, 2009 | 07:53 PM
JaceTun's Avatar
I picked up a can of PB blaster from Wal-Mart. Going to try it again during spring break.
Hope it will do it. or else I have to get a new tool. lol
Thx for the advise yall
Old Mar 10, 2009 | 08:08 PM
AWDrifter's Avatar
Im going to do this this weekend or next. I dont have a torque wrench. How neccesary is one when putting the new mount in?
Old Mar 10, 2009 | 09:35 PM
achTTung's Avatar
Get it tight, but don't shear it off. That pretty much goes for most big bolts on the car.
But... a torque wrench from advance is like, $30-40. It beats guessing.
Old Mar 10, 2009 | 11:02 PM
AWDrifter's Avatar
Hmm i thought they were more than that. Guess ill have to check on getting one
